titebond cold press on wood laminate
Bill123_
Are you supposed to apply Titebond cold press to both surfaces? I'm doing wood laminate repair and I'm avoiding that squeeze out at the seams. Any insights or tips?
Yeah both surfaces for a stronger bond. If you wanna avoid squeeze outs, use just enough glue... thin, even coats, and clamp gently but firmly. Wipe any excess fast before it dries
For laminate repair, you usually just apply it to one surface from what I know. A thin, even coat and a good press should do the trick.
It's usually best to apply it to both surfaces for a strong bond, but applying a thinner layer can help reduce squeeze out. Make sure to clamp properly and wipe away any excess before it dries
There’s no instruction that came with it? I'm trying to laminate a 2.5-foot square tabletop with unbacked wood veneer that didn't come with directions. I'm wondering if cold press Titebond is a PVA glue, because I saw a video that said urea glues are much better for laminating than PVA glues.
Funny how, I just encountered something similar, thanks you guys for the tips, this really helped me. Was actually skeptical about all your suggestions but I actually implemented them
