Rutland dust extractor motor replacement help
Yeaffy
Rutland dust extractor motor replacement help. Would you mind to where I can buy replacement motor.
Had to change the motor on my Rutland dust extractor last summer in my garage. it stopped working in the middle of a project. my brother-in-law found a new motor on Sand Blasters UK, and he mentioned that Rutlands' website also has parts if you know your model. Just check that the power and size match.
When you swapped yours, did the new motor match the mounting holes and wiring, or did you have to modify anything?
Haven't done one but on most dust extractors you usually end up having to drill at least one new mounting hole, the wiring should probably be straight forward too
